94 prelude tranny
Old Mar 9, 2010 | 08:44 PM
HondaAccordEX94's Avatar
Almost A Senior Member
Default 94 prelude tranny
This may or may not be a stupid question. As far as my knowledge goes, I wouldn't know. Lol.
From what I've gathered, the 4th gen (1992-1996) VTEX Preludes has H22A1 engines and transmisions.
If I can manage (And that's not that big of an if, really) to get a transmission out of one of these 4th gen vtec 'ludes, how great of an effect will it have on my F22b1? And if I do the swap, do I have to swap the ECU?
Old Mar 9, 2010 | 09:51 PM
When I swapped in a M2B4 transmission(jdm h22 LSD transmission) it took .7 off my 1/4 miles time.
Some factors to consider:
decreased gas mileage(you will be at a higher rpm at a lower speed)
h23(92-96 non vtec 2.3l preludes) have very similar gearing so either would work
transmissions are notorious for 5th gear grinds.
You wouldn't have the swap the ECU(assuming your car is a manual). Not sure about an automatic, its not my specialty.
Old Mar 9, 2010 | 09:54 PM
F22 trans has taller gears because that engine makes more torque at lower RPM.
H22 trans has shorter gears because that engine makes it's power at higher RPM.
Each is kinda matched to take advantage of the characteristics of the engine. H22 trans on a F22 engine will have it revving high & running out of breath.
Old Mar 9, 2010 | 10:44 PM
Yeah, I have an auto right now.
Thanks for the heads up, guys. I won't do such a swap without the matching engine and ECU.
Old May 8, 2010 | 12:39 AM
patrick076's Avatar
i want to change the rims of my vehicle suggest me other than Honda rims
bigtex
Feb 21, 2018 11:08 AM
tranwreck
Apr 30, 2009 09:27 AM
Leonhartilly
Jun 22, 2007 01:28 PM
2.2ex965spd
Jun 3, 2006 04:14 PM
