96 accord ex engine loses power
Old Oct 10, 2009 | 06:01 PM
edbighead
Default 96 accord ex engine loses power
My 96 accord ex randomly loses power within 5 minutes of getting on the road. Ill step on the gas and it doesn't accelerate or rev. Ive taken it to multiple mechanics and they re all lost. Ive replaced the fuel filter, replaced cat converter , new O2 sensors. any help would be great, thanks in advance.
Old Oct 10, 2009 | 06:14 PM
edbighead
the check engine light also comes on when the problem is bad and then goes back off when it doesnt happen as often. its all v random
Old Oct 12, 2009 | 08:15 AM
What code does it throw?
Old Oct 14, 2009 | 02:56 PM
edbighead
Do I need to read the code when the check engine light comes on? It turns off and on randomly but the problem is def worse when it's on. When I'm on the highway it never loses power but usually when I first start out or after Ive been driving for a while on the highway then stop and star again it'll happen. It's def not the transmission. I've taken it to multiple mechanics and they have no idea whatthe problem is. I'll try to get the code I puts out asap.
Old Oct 14, 2009 | 11:35 PM
19Accord97
You can jump the code w/ a paper clip (in the DIY or FAQ section i think) or go to Autozone for free. It shouldnt have to be on...I dont think.
Old Jan 6, 2010 | 02:26 PM
edbighead
Default code
P0171 or fuel system too lean
Old Jan 9, 2010 | 06:49 PM
edbighead
bump, anyone have any idea what the problem could be?
Old Jan 10, 2010 | 02:29 AM
clutch811's Avatar
im working on a ford focus with the same code. lean condition can be one of two main concepts. 1. either not enough fuel is being put into the combustion chamber or 2. you are not getting any or complete enough combustion in one or more cylinders meaning a miss fire.
1. can include fuel pressure so:
fuel pump
injectors/rail are bad or clogged
fuel filter clogged
fuel leak(not likely)
also can be vacuum leak: check for these at all hoses for the vacuum system.
2. o2 sensors only look for oxygen presence so even if you get fuel but its not burning youre gonna get too much air hence lean condition.
have you tried a tuneup:
cap
rotor
wires
plugs
run a bottle of cleaner through you fuel tank. seafoam would be best or you can use injector cleaner.
hope this helps. sorry if im wrong or missed something its very late lol. oh and look into the egr system i believe this can cause trouble too!
Old Jan 11, 2010 | 07:44 PM
edbighead
ive already done all of that any other ideas haha
Old Jan 11, 2010 | 10:32 PM
clutch811's Avatar
hmm. have you had any other major maintenance done recently like timing belt, etc?
is the car getting adequate fuel pressure? check your coolant, does it look normal? try a compression test. are you absolutely sure the EGR system is clean and operating correctly?
how about your PCV valve?
the engine run really rough? like almost as though theres a miss?
jinpdx
Apr 13, 2026 09:28 AM
Originalhoopty
Jul 13, 2014 08:42 AM
pchaffer
Oct 2, 2012 05:48 AM
vteck2001
Jun 11, 2009 07:29 PM
benjdotgov
Mar 10, 2007 07:01 PM
