96 Accord Throwing O2 Sensor Error
Old Mar 8, 2006 | 03:29 PM
duke16
Default RE: 96 Accord Throwing O2 Sensor Error
I've tried everything I can, but that shield will no budge. I can pull it forwards a little, and then let a little. But not enough to get it over the hard part of the sensor. There's just to much stuff around the shield (pipes and what not). Does the picture I posted look like what you see on yours?
ORIGINAL: 98accrd
You can remove the sensor without removing the shield. I use an O2 socket, or clip the wires (if I'm not reusing the sensor) and use a deep socket.
What's on O2 socket? I can't find any socket big enough to get over the other end of the sensor.
- EDIT -
OH, never mind. I found a picture of one. It has a slit down the edge, I'll try and pick one of those up then. Thanks.
Old Mar 8, 2006 | 09:16 PM
lightshow's Avatar
hey if you shield wont budge then you havent unscrewed all the bolts there is another one or two hiding that you havent found
Old Mar 9, 2006 | 11:10 AM
19Accord97
Hey Duke,
Is your model the 4 cyl? But to answer your question, the picture is the exact same as mine. Though, tonight i'll take a look at mine and make sure there are only 3 bolts and see if my 02 sensor seems to be the same length. Or check your library/autozone and look in a Haynes manual.
Old Mar 9, 2006 | 08:18 PM
duke16
ORIGINAL: lightshow
It moves just fine, like I said though, there isn't enough space to remove it.
All is good now though, I got a socket and didn't have to remove the heat shield at all.
BigShelby
Dec 18, 2015 09:36 PM
Fat Ryan
Oct 21, 2011 06:54 PM
vancent60610
May 19, 2010 07:41 PM
CasualObserver
Dec 14, 2006 02:06 AM
duke16
Mar 5, 2006 04:10 PM
