98 accord engine problem
Old Mar 25, 2007 | 11:26 PM
scheung1990
Default 98 accord engine problem
I had my 98 accord v6 timing belt and water pump change about a month ago. when i start up the car, its making some weird noise, sounds like its rubbing against something. Does this about everytime the car is started up and probaly while running.
Any solution to this problem or probaly bad repair?
Old Mar 26, 2007 | 12:41 AM
droopy128
Default RE: 98 accord engine problem
Did you change the tensioner with the repair, it could be that.
Old Mar 26, 2007 | 01:14 AM
deserthonda's Avatar
ORIGINAL: scheung1990
you need to take the car back to the shop that worked on it and have them take a look at it ..they might have left something loose ,, but give them a chance to fix it properly if it is indeed something that they did
trouble
Aug 21, 2012 07:46 PM
kellysa111
May 1, 2009 08:35 AM
StatzFinest
Feb 10, 2008 11:32 AM
hopkinted
Dec 30, 2006 04:41 PM
ferry
Jun 13, 2006 10:09 AM
