99 Accord 4 cyl Timing Belt
Old Mar 30, 2007 | 04:11 AM
jombolo's Avatar
Default 99 Accord 4 cyl Timing Belt
Does anyone know if the 4 cyl. engine on my 99 accord is interfering or non-interfering. i haven't had time/money to replace the timing belt and its over 105k. Anyone know for a fact either way? thanks.
Old Mar 30, 2007 | 11:14 AM
Default RE: 99 Accord 4 cyl Timing Belt
It's an interference engine. If the belt breaks, the pistons can hit the valves.
Old Mar 30, 2007 | 11:04 PM
j_man_honda's Avatar
Yeh honda engines depend a lot on the timing belt. As long as you keep it replaced whenever the time comes your engine will be fine. I'd advise you to change yours just to be safe.
Old Mar 31, 2007 | 04:26 AM
deserthonda's Avatar
ORIGINAL: jombolo
. i haven't had time/money to replace the timing belt and its over 105k..
You are on borrowed time ,, even worse if you do mostly city driving ,,You have to keep in mind that anytime you are stopped at red lite or behing traffic, odometer will not go up but the timing belt still spins ,, so in reality timing belt has a lot more miles that the odometer reading ..
Old Mar 31, 2007 | 01:15 PM
Evlampius's Avatar
Plus I wanted to add that even though the belt might not break apart - it does stretch - so as you are driving it further you might experience bad acceleration and/or worse gas mileage
dschnarr
Oct 5, 2011 09:06 AM
fraughton
Feb 15, 2009 09:12 PM
dcsmith
Aug 19, 2007 08:19 AM
deserthonda
Apr 4, 2007 04:05 AM
Tony1M
Apr 1, 2007 05:42 PM
