Accord 2004 Automatic Transmission oil
Old May 27, 2007 | 01:24 AM
oziking's Avatar
Default Accord 2004 Automatic Transmission oil
I am using 6cyl Accord 2004 with automatic transmission. Dealer told me that i must change automatic transmission oil after 80,000KM.
People says that usually changing the automatic transmission oil destroys the gearbox etc and ends up in lots of problems. Friends says better dont touch it unless its dirty.
Please help me on that.
Old May 27, 2007 | 10:31 AM
Chiovnidca's Avatar
Default RE: Accord 2004 Automatic Transmission oil
If it was mine i'd change it more often than honda reccomends. New fluid isn't going to hurt it. Use Honda ATF.
Old May 27, 2007 | 11:43 AM
RTexasF's Avatar
Super Member
ORIGINAL: oziking
It's obvious that "people" and "friends" don't know jack about cars!! I agree with above: Use only Honda fluid and change it more often than is called for. Drain & fill only NO flush!
Old May 28, 2007 | 07:05 AM
YeuEmMaiMai's Avatar
the 5spd auto used in those cars is the same one used in the Acura CL/TL cars. It is STRONGLY RECOMMENDED that you change the fluid every 30K miles
Old May 28, 2007 | 10:03 AM
oziking's Avatar
thanks a lot for your answers i will get it changed soon.
Really appreciated
Old May 28, 2007 | 02:16 PM
BATerrell's Avatar
ORIGINAL: YeuEmMaiMai
the 5spd auto used in those cars is the same one used in the Acura CL/TL cars. It is STRONGLY RECOMMENDED that you change the fluid every 30K miles.
I don't even know if I'd let it go that long. But hey, 30k is better than " I've got 145k on my auto and never changed my fluid"..... Oh boy.
sonscar
Nov 11, 2014 03:18 PM
Rilex
Jan 5, 2013 11:00 AM
Slobbo
Jun 9, 2010 04:35 PM
b12yan12
Apr 3, 2010 10:34 PM
oziking
Jan 23, 2008 03:01 AM
