Another A/C question
Old Sep 1, 2008 | 01:32 PM
Mexjames
Default Another A/C question
The car: 2008 Accord EX 4-cyl.
The "Auto" feature of the A/C system seems to work only when I set the temperature all the way down, to "Lo". If I set the temperature say, two notches above "Lo", the fan stays put in one speed. Also, if I go under the sun and then drive through a tunnel, etc., the fan won't vary its intensity.
We also have an '03 Ody, and if its in direct sunlight or under some shadow, or even driving under the clouds, the fan will vary its speed accordingly.
Is the Accord's A/C system working the way it should?
Old Sep 2, 2008 | 01:15 PM
finch13's Avatar
Default RE: Another A/C question
My advice: take it to the dealer, it's still under warranty. On our '04 Acura MDX the Auto feature only regulates the fan speed in order to get the car to that temperature as quick as possible, like turning the A/C all the way cold when it's blistering hot outside...
Just take it in an complain, if need be, drive a floor model around with the same A/C controls to prove that it isn't working correctly.
Old Sep 4, 2008 | 09:34 AM
Mexjames
I hadn't thought of driving say, the demo car and see how the system works. I paid a little more attention, and this system also seems to regulate the speed of the fan. I'm used to my wife's Ody, though, which has a lower low temp and a lower high temp than this Accord.
Old Sep 4, 2008 | 10:02 AM
finch13's Avatar
ORIGINAL: Mexjames
That's just what we say around here! The 08s haven't been around long enough for most of us to know anything about them... so if you have an issue that should be covered under warranty, we say take it in! But if you want help voiding your warranty we can certainly help
Old Sep 4, 2008 | 10:18 AM
Tippman7641's Avatar
in my moms 08 v6 she hits auto and all u see is the temptures, no fan control, as soon as u change anything but tempture, the auto light goes off, and the fan varies
HondaAccordKid
Oct 28, 2010 11:32 AM
silver03
Dec 27, 2007 07:31 PM
HAcc407
Mar 22, 2006 01:25 PM
Irish Kevin
Mar 18, 2006 09:41 PM
F23AccordLX
Dec 7, 2005 07:52 PM
