bent valves??
Old Aug 27, 2007 | 01:10 PM
ooo5
Default bent valves??
First off, I am new to this forum and to Honda's. I have a Ford Lightning and am on svtperformance forum, but am looking at buying an accord from a friend for a daily driver. The accord is a 4cyl. and from what I have been told, the timing chain broke and the valves were bent. My question is, do I just need to buy a new head with valves and put it on or do I need to buy a whole new motor???
I am going to look at the car for the first time today so I will have more info after that. For now all I know is that it is a 96 or 97 accord coupe with a 4 cyl. and auto.
Thanks in advance for any help/advice
Old Aug 27, 2007 | 01:25 PM
Default RE: bent valves??
its possible that you only need a new head, but the pistons or rods could have been damaged as well, as far as i know the only real way to know is to take it apart.
Old Aug 27, 2007 | 01:30 PM
00AccordLX5spd's Avatar
Registered User
If the timing belt broke, there could be a multitude of problems in addition to bent valves (i.e. pistons, valve guides, etc..)since Hondas are interference engines. If I were you I would shop around for a used motor and also price a complete rebuild for the motor currently in the vehicle.
Old Aug 27, 2007 | 05:55 PM
Chiovnidca's Avatar
Or there could be no problems at all besides slapping a new belt on it.
Old Aug 27, 2007 | 06:07 PM
deserthonda's Avatar
how did they know that valves were bent ?? did they do a leakage test ?? pull valve cover off and manually chk too much movement on rocker arms or just took a guess ??
if indeed the valves are bent .. you need to pull the head and see if there is other damage if not, replace the bent valves, repalce all the valve seals and put it together no need to buy a new or used head if there is no damagwe to the head ..
but like Chio said ,, make sure that it is not just a broken timing belt only ...
Old Aug 27, 2007 | 06:40 PM
sir_nasty's Avatar
ORIGINAL: ooo5
I'm guessing that this was just a typo but I thought I'd mention it anyway. The 96/97's used a belt not a chain.
HiMilesJ
Dec 23, 2012 06:05 PM
redhardino
Feb 2, 2008 08:35 PM
Catcanski
Oct 31, 2007 10:53 AM
redsailtx
Oct 27, 2007 10:41 PM
Mpwr
May 12, 2006 04:14 AM
