Bent valves I think
Old Jan 23, 2022 | 02:28 AM
Ndhadaway's Avatar
Default Bent valves I think
Hey guys I have a 2003 accord 2.4l auto. and my starter went out a few weeks ago. I just got around to replacing it and when it started it was a very rough start and ran rough, also the engine would almost stall out then jump to 1000-1200 rpms. I noticed the cam timing was off and when I put a piece of paper against the exhaust pipe it blows out then sucks back in rapidly. I also hear ticking that sounds like it’s coming from just under the valve cover. Does this mean I have bent exhaust valves or stuck lifters? And if a valve is bent can I adjust it enough to drive around? The car drives fine (just loss of power) but runs extremely rough at idle and almost stalls when I let go of the throttle. Compression is also good in all 4 cylinders. Please help this was my first car and I still love it. It has 230,000+ miles.
Old Jan 23, 2022 | 08:48 AM
shipo's Avatar
Given your Accord has a K24A4 engine which features a timing chain instead of a timing belt, it is relatively unlikely, but not impossible, you have bent valves. At this point I would suggest you get a professional to diagnose the issue.
jroxz44
Jan 14, 2013 03:33 PM
Rice
Jun 26, 2012 06:01 PM
drummer1279
Mar 15, 2012 08:59 AM
eleiko
Jun 15, 2011 10:46 PM
draser
Apr 11, 2011 07:33 PM
