Broke Tach
Old Jan 4, 2008 | 05:46 AM
Joseph's Avatar
Default Broke Tach
So my tachometer since i bought my car hasnt worked - any tips or suggestions on what i should do to attempt to fix it?
Im willing to try anything at this point - it bugs the crapola out of me....
Old Jan 4, 2008 | 08:42 AM
00AccordLX5spd's Avatar
Registered User
Default RE: Broke Tach
Is the tach totally dead (on 0 all the time)? Or does it wildly jump around? Does the engine seem to shudder or anything?
Old Jan 4, 2008 | 07:02 PM
Joseph's Avatar
stuck on 0 always, everything runs flawlessly.
Old Jan 4, 2008 | 09:39 PM
Chiovnidca's Avatar
check engine light on? any stored trouble codes?
Old Jan 5, 2008 | 05:48 AM
Joseph's Avatar
check engine light comes on and off - i reset it, couple trips in it, and it comes back on.
I dont know what to do anymore [:@]
Old Jan 5, 2008 | 06:50 AM
Chiovnidca's Avatar
ORIGINAL: Joseph
What trouble code does it have stored?
Old Jan 5, 2008 | 07:18 AM
Joseph's Avatar
Im not too good with understanding what your talking about haha
Explain this to me as if i know nothing about cars.....I dont even know what trouble codes are []
Old Jan 6, 2008 | 10:54 PM
If thecheck-engine lamp is on, the ECU stores an error-code to help you narrow down the search for the problem.
Old Jan 7, 2008 | 08:25 AM
Registered User
pull the ashtray straight out. There is a service connector there. Take the car to AutoZone and have them hook an OBDII code reader to the port you uncovered by removing the ashtray. Have them print out the code number or write down the code number and post it here. They will try to tell you what the problem is, but their computer's explanations are often inaccurate for Hondas. Post the exact code # here. It should look like P####.
I would be willing to bet itis going to give you an ignition coil fault.
g22cd5
Nov 5, 2010 01:29 AM
Chiovnidca
Apr 2, 2007 10:54 PM
kennilope
Mar 10, 2007 12:16 AM
shawn till dawn
Jan 24, 2007 04:34 PM
monicarae02
Jul 14, 2006 02:40 AM
