Car sometimes shuts off on me?
Old May 27, 2007 | 08:06 PM
pyaarawala's Avatar
Default Car sometimes shuts off on me?
On rare occasions, my car, after starting it, will just shut off on me. After starting it, it shakes a little, then turns off, and my Battery Light and Oil Light (in red) come on and stay on. I already changed my battery, hoping that that was the issue, and it hasn't happened for a while. Only today, after installing my header, it finally happened. After a few tries, it always starts up again and is perfect for the next few days. The only thing I'm hoping that will do the trick is a tune-up. Anyone know what's wrong? Also, when I turn off my car, the engine block shakes a little, kinda the way it shakes when your car loses ignition without your intention of losing ignition. Does that have anything to do with this? Thanks.
Old May 27, 2007 | 08:31 PM
Chiovnidca's Avatar
Default RE: Car sometimes shuts off on me?
Have you checked the main relay for cracked solder joints?
Old May 27, 2007 | 10:03 PM
pyaarawala's Avatar
You lost me there, what do I need to check specifically and how?
Old May 28, 2007 | 06:45 AM
mig25's Avatar
This is a really weird one, I am curious myself to find out what it is.
For some reason I might think your car is starving for fuel.
Do the easy stuff first, make sure your fuel filter is not clogging up, whenwas it replaced last ?Also do a search on Fuel Pumps and relays.
Good luck
Old May 28, 2007 | 07:35 AM
BlkCurrantKord's Avatar
Sounds like ignition coil.
Old May 28, 2007 | 11:08 AM
pyaarawala's Avatar
Where is the fuel filter and what you mean by ignition coil?
Old May 28, 2007 | 11:57 AM
ORIGINAL: pyaarawala
The fuel filter is in the tank and shouldn't ever have to be changed since the pump/filter is all one unit. The ign coil is in the distributor.
Old May 28, 2007 | 01:58 PM
pyaarawala's Avatar
Wow so I guess it can't be the fuel filter. About the distributor, it can be a problem. I was going to buy new plugs and wires and possibly a distributor cap, hoping that will solve the problem.
Neptun3
Oct 22, 2014 05:56 PM
vova
Feb 26, 2012 09:52 PM
njmodi
Dec 16, 2011 10:06 PM
chrisbenoit
Dec 16, 2010 08:32 PM
cuatro201821
Apr 1, 2008 09:06 AM
