Car shuts off in middle of shifts!!! help
Old Dec 16, 2010 | 03:01 PM
chrisbenoit's Avatar
Default Car shuts off in middle of shifts!!! help
Hi guys, new to the forum. I have a 1999 accord DX, 2.3 liter, 5spd. Sometimes the car will shut itself off in the middle of shifts. The car should idle down to approx 700 rpm or so, but sometimes it will drop too low like it's hunting for it's idle speed but in the process will drop too low in the rpm's and stall out. I can start it back up and it will idle right away. I also scanned the codes and nothing came up.
PS. the ignition switch was already replaced.
Thanks.
Old Dec 16, 2010 | 06:51 PM
Is the check engine light turning on? Stop by a parts store and have them scan for codes anyway. Have them test the battery, alternator, and starter while they are out there.
If you had the ignition switch replaced, the new switch was the same as the original one. So a Honda replacement ignition switch can fail. Can you get the car to stall out by shaking the key while driving?
Are the maintenance items up to date like distributor cap, rotor, spark plugs, air filter, etc?
Old Dec 16, 2010 | 08:32 PM
Believe it or not, Honda's idle-control system doesn't like to have air pockets in the cooling system. Check for that.
Also... Look to see if your throttle body and/or throttle butterfly-plate needs to be cleaned up.
Look in the DIY section for something I wrote about adjusting the BASE idle. Misguided adjustment of different things can confuse the idle-control system. It'll work OK most of the time but fail to catch a dropping RPM during a shift.
anbu7elite
Sep 11, 2019 11:07 AM
Butterd97
Aug 22, 2014 07:47 AM
vova
Feb 26, 2012 09:52 PM
njmodi
Dec 16, 2011 10:06 PM
pyaarawala
May 28, 2007 01:58 PM
