check engine
Old Jul 30, 2006 | 12:48 AM
Breeze's Avatar
Default RE: check engine
It sure does!! I am not the original owner of my accord.
Old Oct 1, 2007 | 11:07 AM
sharonaf
I have code P1491 & P0171 per the check at autozone. I have a 96 honda accord ex, 4cylinder, 4 door. I had a new fuel filter and pump put on ( as that was suggested) and also made sure the gas cap was on correctly and the check engine light is still on. Is there a sure way of knowing what needs to be replaced before I just start replacing things that don't need to be replaced?
Old Oct 1, 2007 | 11:18 AM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: sharonaf
1st of all, you should probably start a new thread, you may get more help that way.
2nd, try using the search function on this website.
I found this thread with little effort: https://www.hondaaccordforum.com/m_47326/tm.htm
P0171 is a "system too lean" code from what I just researched.
RA1525
Apr 15, 2012 07:50 AM
blahblah
Mar 18, 2007 02:33 PM
hopkinted
Dec 30, 2006 04:41 PM
99 EX V6
Mar 3, 2005 03:42 PM
