Check engine lamp
Old Feb 22, 2008 | 07:59 AM
theswede
Default Check engine lamp
Hi
my check engine lamp is on I have an Accord 90 2,2 i and i see the code on PGM is 4 lång and 1 short blink
Is this for Oxygen (Lamda ) before Cat or? canI check if Lamda is Ok with elictrical instrument
Peter
Old Feb 22, 2008 | 11:53 AM
Default RE: Check engine lamp
4-long & 1-short is code 41 - elecric heater built into the O2 sensor. In 1990 there's only one sensor.
Unplug the O2 (lambda) sensor & look for 2 same-color wires (black?) on the sensor. Resistance between those should be 10 to 40 ohms. If it's not, you need a new sensor.
LS-300
Mar 3, 2012 08:33 AM
hondafix
Feb 7, 2008 09:44 PM
tce23233
Dec 22, 2007 11:26 AM
blahblah
Mar 18, 2007 02:33 PM
djsinister
Mar 1, 2006 03:11 AM
