CKP Sensor
Old Nov 30, 2007 | 11:24 AM
doanutboi's Avatar
Default CKP Sensor
i recently did the obd II code reader test on my car and it was throwing out the code P0335 which was Crank Shaft Position Sensor Malfunction, is it necessary to replace the whole crankshaft position sensor? or is it just a wiring problem. I recently changed out my timing belt, and now the car won't rev past 3000rpm. The belt snapped but there seems to be no problem with the compression and no bent valves. thanks in advance for the advice.
do you guys know how much a CKP sensor goes for(h22a4)??
Old Nov 30, 2007 | 03:55 PM
ckebottle's Avatar
Default RE: CKP Sensor
This recently happened to my gfs civic. Don't know if this will help but the mechanic found that there was a short in the wire due to water. Mechanic said some grommet corroded and allowed water in. Maybe there is something wrong with the wiring and not the sensor? I don't know much about wiring so hopefully somebody else will chime in.
Old Dec 1, 2007 | 08:31 AM
BlkCurrantKord's Avatar
Take the timing cover off and check the sensor and its wiring.
Old Dec 2, 2007 | 06:35 AM
doanutboi's Avatar
there were a couple rips in the wiring but i already taped it up, how would i know if the actual sensor was damaged?
Old Dec 2, 2007 | 11:38 AM
Test it with a voltmeter.
Old Dec 2, 2007 | 08:28 PM
Chiovnidca's Avatar
ORIGINAL: doanutboi
Hmmm, let me think......................
Old Dec 3, 2007 | 09:04 PM
doanutboi's Avatar
any other advice guys? the new ckp sensor is 187..[&:]..and right now i dont have that kind of money to spend. with christmas coming up and all
WayneG0531
Sep 22, 2014 12:31 PM
ddodge21
Sep 13, 2014 12:46 AM
beaveraccord
Nov 25, 2013 08:21 AM
Roader
Jan 19, 2013 09:23 AM
steven78418
Jun 14, 2011 02:56 PM
