Cylinder head bolt snapped!
Old Sep 22, 2007 | 06:11 PM
troy331's Avatar
Default Cylinder head bolt snapped!
ok so i have been fixing the cylinder head on my sisters 93 accord when i am torquing up the canshaft bolts and one decides it wants to snap! Bastard! anyone know of a way out witout having to send it to the shop. Thanks
troy
Old Sep 25, 2007 | 11:43 AM
troy331's Avatar
Default RE: Cylinder head bolt snapped!
got it sorted! snapped 2 more after that. I think the old bolts were just worn or someone over tightened them previously.
Old Sep 25, 2007 | 10:40 PM
HuYnHness's Avatar
have you tried looking for broken screw/bolt extractors. like this one
http://www.4grabit.com/
Old Sep 25, 2007 | 11:38 PM
Tony1M's Avatar
ORIGINAL: troy331
..................I think the old bolts were just worn or someone over tightened them previously.
Yeah, that's what they all say!
Old Sep 29, 2007 | 02:46 PM
KevinAccord's Avatar
use some stractors man!
Old Sep 29, 2007 | 10:02 PM
Velocifero's Avatar
Sears sells some bolt extractors too
Old Oct 4, 2007 | 08:15 PM
nafango2's Avatar
im prolly totally wrong on this one, but if you took all the other bolts out couldnt you just pull the head up? considering theres no head on the bolt.... then just use some vicegrips and a steel pipe?
Old Oct 4, 2007 | 09:59 PM
Velocifero's Avatar
ORIGINAL: nafango2
it generally shears off where most of the pressure is, of course, which is this case is in the head. that means it's usually flush with the metal it is screwed into. im only guessing from experience.
Old Oct 4, 2007 | 11:10 PM
nafango2's Avatar
gotcha.
that makes more sense.
Old Oct 7, 2007 | 09:41 AM
One way of resolving this is to lay a nut w/ ID just smaller than the hole ID. Weld the nut to the broken end of the bolt and back the bolt out. Hopefully release of the tension when the head snapped out will allow removal fairly easily. This should not have happened. I agree w/ troy331 that someone probably yielded the bolts on previous installation w/ severe overtorque.
Not clear if he's got broken camshaft hold-down bolts or cylinder head bolts. If cylinder head bolts you could remove the cylinder head over the broken bolts and make welding a nut very easy.
adrian750
May 16, 2013 05:25 PM
MessAround
Jun 29, 2011 06:02 PM
HondaAccordEX94
Apr 5, 2010 04:27 PM
reinventingaxlrose
Jun 5, 2009 11:43 AM
Jay 3rd
Mar 16, 2008 12:02 PM
