Does anyone know if this will work and if anyone has seen it done?
I was looking around at turbo specs on evos and seen that gh he evo 7 uses a 85mm piston. Would these fit on f22 rods and would the compression be simular to the evo. Also do you think the exhaust manifold would work? Thanks for the input. I think it would be a interesting set up
ppl use the evo stroker pistons in f22 blocks a lot. I'm glad to see someone has done their homework and is willing to think outside of the box. Just make sure to do good research on that set up. cb7tuner.com has good bit of info on using evo pistons in f22a engines
Thought the evo ran 9.4/1 cr. Just thought it may raise cr a little. AnY way thought it would be a sick combo. Kinda like a 2.2 evo motor. Would there be a benifit to running those pistons or no?
So what you saying is same cr so probably no better than the pistons I have. If thats the case what would be a good choice down the road? I want something not everyone has. Would like to make 250 whp maybe 300 topps above that would be crazy, couldnt get it to the ground. Anyway im open for outside the box ideas. The build would be on down the road as my motor runs good but may pick up another block to play .
Im still putting the car back together as we ripped most the car apart to fix wiring and such thanks in advance for any.
input.
input.
ppl use the evo pistons b/c they are stronger than f22 stock pistons. Ringlands don’t fail and cause catastrophic damage. From what I have read stock evo pistons will handle around 400ish hp. Stock f22 are gettin push to limits at 300hp...so out the window with reliability. So even know your keeping around if not the same compression ratio you getting a much stronger piston.
well your gonna need some head work to pass the 300hp goal and at the point if your swapping out pistons you might as well get rid of the f22 rods and get something stronger.
just remember you can have 2 of the 3...
cheap
fast
reliability
chose wisely
cheap
fast
reliability
chose wisely
fondahonda
Dec 14, 2011 06:21 PM
06 Accord
Feb 3, 2006 02:02 AM
