Egine Check Light is On
Old Sep 27, 2007 | 11:50 PM
Per545
Default Egine Check Light is On
just brought a 99 EX-V6. after filling it up the check engine light came on.the gas cap is on securely. this is the first time i have experienced this, how long before it goes out?
Old Sep 28, 2007 | 01:54 AM
superballz00's Avatar
Almost A Senior Member
Default RE: Egine Check Light is On
Did you gas cap click at least 3 times when you tightened it? If it is your gas cap then it should go out in 3 days if im not mistaken.
Old Sep 28, 2007 | 10:39 AM
00AccordLX5spd's Avatar
Registered User
It won't go out on its own. If it really was thrown by a not-completely tightened gas cap (I have done this several times on my 2000 LX) you still need to reset the ECU. Make sure you have the radio code (if you have the stock EX radio) and pull the "backup/radio" fuse under the hood. That resets the ECU. There are instructions in the DIY section.
Old Sep 28, 2007 | 03:03 PM
In 1999 that fuse isn't under the hood.
Fusebox in the right-end of the dashboard, near the door hinges. Fuse #13.
Old Sep 28, 2007 | 03:08 PM
Registered User
Woops...I got it confused with my 95[&:].
AspiringMechanic
Jun 8, 2014 08:59 AM
Dgkboi
Sep 1, 2012 08:56 AM
HondagalGA
Nov 6, 2006 08:20 PM
62maxx
Oct 26, 2006 01:04 PM
hotrod01
Nov 11, 2005 01:28 AM
