97 accord egine light
Old Aug 31, 2012 | 08:55 AM
Dgkboi's Avatar
Question 97 accord egine light
So i hAve a 1997 v6 accord and the check engine light was on due to the 02 sensor. So during the change i noticed my accesory belts needed replacing so i changed them but left the ac belt off. Can that cause the check engine light to stay on since i replaced the o2 sensor?
Old Aug 31, 2012 | 09:13 AM
I moved this from the DIY section to the General Tech Help section. As per the forum rule, please don't post help questions in the DIY section.
Welcome to the forum.
Old Aug 31, 2012 | 05:23 PM
AccorDats's Avatar
did your reset the ecu after the o2 install? id didn't it will still stay on.
to reset the ecu, remove negative battery terminal for about 20mins, put it back, start the car without any pedal on gas wait for the fan to turn on, then you're good.
goodluck
Old Sep 1, 2012 | 08:56 AM
What is the actual code you are getting? "P" and four digits.
AspiringMechanic
Jun 8, 2014 08:59 AM
Per545
Sep 28, 2007 03:08 PM
HondagalGA
Nov 6, 2006 08:20 PM
bigdude
Oct 1, 2006 07:03 AM
