engine hesitation HELP
when stepping on the gas real quick, you feel a vibration and it sounds like the engine is under alot of strain then revs up. what could be the problem? also when i step on the gas and release, the idle drops low real fast and returns back to normal?
What car? Year?
Maybe the IACV but you should first go through this post.
https://www.hondaaccordforum.com/for...e-speed-38734/
Automatic trans 1997 or older? Possible throttle-to-transmission cable adjustment.
gtg162y
Jan 2, 2009 10:55 AM
