engine hesitation HELP
Old Sep 11, 2011 | 09:02 PM
noahkeeberCD5's Avatar
Default engine hesitation HELP
when stepping on the gas real quick, you feel a vibration and it sounds like the engine is under alot of strain then revs up. what could be the problem? also when i step on the gas and release, the idle drops low real fast and returns back to normal?
Old Sep 12, 2011 | 12:16 AM
bigpat's Avatar
Almost A Senior Member
Check and replace the air filter element, also clean the throttle body. You could also try cleaning the EGR ports.
Old Sep 12, 2011 | 08:51 PM
what about the idle control valve?
Old Sep 12, 2011 | 09:13 PM
What car? Year?
Maybe the IACV but you should first go through this post.
https://www.hondaaccordforum.com/for...e-speed-38734/
Automatic trans 1997 or older? Possible throttle-to-transmission cable adjustment.
POLISHDON
Oct 11, 2019 06:02 AM
robertL
Aug 5, 2015 08:39 PM
noltian
May 21, 2011 08:51 AM
MisterBen
Nov 21, 2009 06:19 PM
gtg162y
Jan 2, 2009 10:55 AM
