Engine shuts off after starting
well right now its about 45-60 degrees F outside, but it just started happening recently. It will happen when the engine is hot or cold though, i could use the car for an hour shut it off for 10 mins and try to restart and it will take like 5 times. I have to give it alot of gas and if i let off the gas it will shut off.
search around the forum for "main relay" you may have that age old problem, luckily it's a cheap fix.... it's more commonly related to starting issues but it's not a bad thing to check out.... any lights or codes or does it just flat out die?
anbu7elite
Sep 11, 2019 11:07 AM
blackaccord01
May 16, 2014 09:21 PM
SandMan
Aug 20, 2007 03:34 PM
