Engine shuts off after starting
Old Dec 17, 2006 | 01:12 AM
Sparco_racingVTEC's Avatar
Default Engine shuts off after starting
sometimes when i turn on my car, it will sputter and then shut off...unless u rev the engine and throw it in reverse real quick or something
Old Dec 17, 2006 | 05:06 PM
Slusher's Avatar
Default RE: Engine shuts off after starting
Does this happen when the engine is cold or warm or just whenever?
Old Dec 18, 2006 | 06:05 PM
well right now its about 45-60 degrees F outside, but it just started happening recently. It will happen when the engine is hot or cold though, i could use the car for an hour shut it off for 10 mins and try to restart and it will take like 5 times. I have to give it alot of gas and if i let off the gas it will shut off.
Old Dec 18, 2006 | 06:43 PM
sir_nasty's Avatar
what year/model is it?
Old Dec 19, 2006 | 11:48 AM
1995 Honda Accord V6 Lx 4D
Old Dec 19, 2006 | 01:55 PM
sir_nasty's Avatar
search around the forum for "main relay" you may have that age old problem, luckily it's a cheap fix.... it's more commonly related to starting issues but it's not a bad thing to check out.... any lights or codes or does it just flat out die?
Old Dec 21, 2006 | 02:28 AM
sputters and dies, no warnings or anything, seems like the engine isnt getting enough fuel
Old Dec 21, 2006 | 02:37 AM
Get yourself a fuel pressure tester and check to see what the fuel pump is putting out..
anbu7elite
Sep 11, 2019 11:07 AM
blackaccord01
May 16, 2014 09:21 PM
o440
Aug 11, 2008 11:07 PM
mike_tran
Aug 22, 2007 05:17 PM
SandMan
Aug 20, 2007 03:34 PM
