f20b auto tranny problem
Old Oct 23, 2014 | 04:00 AM
scpike's Avatar
Default f20b auto tranny problem
I have a 2001 accord with a f20b swap and auto transmission. The transmission won't shift... It will go into reverse, sometimes 1st gear but when it hits 21mph and tries to shift to 2nd it just pops neutral and revs. Then I have to fight for it to go back into 1st. Is that the transmission or a wiring or shift solenoid problem? Any help would be appreciated. Thanks
Old Oct 23, 2014 | 06:59 AM
Any Check Engine LIght or D4 light flashing? A code would provide a clue.
Old Oct 24, 2014 | 07:49 AM
scpike's Avatar
No, no codes and no flashing D4
Old Oct 24, 2014 | 07:57 AM
When you turn keyswitch from Off to On, does Check Engine Light (CEL) come on for 2-3 secs and go off? If not, CEL may not be working.
There is an extensive list of problems that don't set trans codes (CEL), and in some cases match your symptoms partially. Suggest finding an emanual online or purchase an emanual from automanualsource.com ($22).
bigtex
Feb 21, 2018 11:08 AM
01f20accord
Aug 31, 2013 05:43 PM
chastings
Jan 2, 2012 10:13 PM
VTECPWR
Dec 6, 2006 11:55 PM
dejavu247
Dec 4, 2006 07:50 PM
