F22 n/a build or H22 n/a build?
Old Aug 16, 2007 | 05:11 PM
Velocifero's Avatar
Default RE: F22 n/a build or H22 n/a build?
ORIGINAL: sir_nasty
I've read that the H22 to a B series motor is only 8 lbs but I'm fairly certain that an f22 weighs less than a B Series....
you guys need to lay off the pipe. this is from Sportcompactcarweb.com,
"The H22, at 385 pounds for the engine, trans and axles, will add between 45 and 65 pounds to the nose of the car, depending on what your Accord had to begin with. Unless understeer is your game, you'll want to put the nose on a diet or pick from one of the many suspension options that grace these pages to support the added weight." link: http://www.sportcompactcarweb.com/te...wap/index.html
a CF hood is about 35 lbs lighter than stock, so it almost evens out.
Tek310
Sep 23, 2011 09:47 PM
jdmaccordcd5
Apr 28, 2011 12:53 PM
HondaAccordEX94
Oct 14, 2010 02:59 AM
AbaZ
18
Jul 16, 2008 10:23 PM
yosfynest11190
Feb 7, 2007 02:42 PM
