F22B2 wont crank
Old Mar 8, 2015 | 02:35 PM
RandyCrazyTrini's Avatar
Default F22B2 wont crank
hey guys i just finished bolting up everything on my engine after replacing my timing belt and the headgasket and i go to start it and it wont crank. All the lights and radio come on but the engine wont do anything.Thanks and its a 1995 honda accord lx
Old Mar 8, 2015 | 03:21 PM
Suggest first checking timing alignment to make sure that engine crankshaft/camshaft timing is aligned.
If good, then turn keyswitch to On and listen for fuel pump to come on for 2-3 secs and go off. Check Engine Ligt (CEL) should go off at same time.
If you don't hear fuel pump, then Main Fuel Relay (MFR) or fuel pump sticking are likely. Confirm whether MFR is delivering power to the fuel pump.
If you hear the fuel pump and no-start continues, then spark is likely missing.
Check that distributor is getting 12V on Blk/Yel wire at the connector to the distributor. Lack of 12v would suggest an ignition keyswitch assy fault.
If you're getting power to the distributor, then ignitor or coil are likely source of lack of spark.
See following link for testing of ignition.
Honda Acura Starting Problems Repair Guide, Main Relay Locations
Old Mar 8, 2015 | 04:01 PM
hey thanks for the help. It ended up being a loese wire. the bad news is that i have a bent valve thanks to the machine shop. Isnt that just great.
Old Mar 8, 2015 | 06:43 PM
woody31's Avatar
Almost A Senior Member
The machine shop did not bend the valve,,it happens when the timing belt breaks and the piston hits the valve out of time. Good luck on the next repair.
Old Mar 9, 2015 | 06:51 AM
The timing belt didn't break. I only replaced it because I had everything off as I was doing a head gasket. My head was fine until it came back from the machine shop.
aborbonio
Feb 24, 2010 11:38 AM
xang0
Jul 6, 2009 03:22 PM
wietgr
Nov 22, 2007 10:50 AM
eazyazamp
Apr 5, 2007 01:52 PM
