Fill up problem
Old Oct 26, 2007 | 08:08 PM
H4L
Default Fill up problem
I have a 99 Accord 4cyl and whenever I fill up on gas it doesnt go all the way down the fuel pipe. It just lingers in there not wanting to go down and the next day my fuel gauge is at like 3/4 full. Has anyone seen a problem like this b4? I think it may be a charcaol canister or maybe one of the lines are clogged. Any suggestions???
Old Oct 26, 2007 | 08:59 PM
Chiovnidca's Avatar
Default RE: Fill up problem
Maybe the fuel sending unit is off a bit?
Old Oct 26, 2007 | 09:14 PM
What does the Honda Dealer say about that problem?...have you called them up about it yet?
Old Oct 26, 2007 | 09:38 PM
H4L
Have not contacted the dealer about it. Would the sending unit be in the fuel tank?
Old Oct 27, 2007 | 02:26 AM
smaglik's Avatar
so it acts like a full funnel and goes down slowly? or wont go down at all?
Old Nov 3, 2007 | 10:49 PM
peter4jc's Avatar
ORIGINAL: H4L
Earlier this year I had a similar situation. CEL light w/ a P1456 code; cannister shut valve. It took forever to fill up, and the pump would click off like it was full. I replaced the shut valve (don't do the cannister unless you know you have to). It took care of the CEL light, and the fill-ups are normal.
Old Nov 4, 2007 | 07:26 PM
I had a bad EVAP canister vent-shut valve ('98 Accord).It set off the check-engine light, but mine never did that when filling the gas tank. So... that's not a very strong diagnostic proof of a bad valve.
There's a couple vent lines running alongside the main gas fill pipe. Check ifany of those are kinked or pinched.
Incidently, the charcoal canister (EVAP canister) isn't really about venting the tank during fillup. It's about trapping evaporation from the tank while the car's parked.
hyperphase
Jul 11, 2007 02:49 PM
cchiller
Jun 3, 2007 10:19 PM
gliff159
May 8, 2007 02:27 AM
mrmookie123
Feb 22, 2007 11:09 PM
Mulaka
Apr 8, 2005 03:22 AM
