Fun with my laptop- getting to know my cars ECU
Old Aug 17, 2012 | 02:25 PM
RobinsonRicer's Avatar
Default Fun with my laptop- getting to know my cars ECU
So I'm really getting interested in ECU tuning and Diagnosis. I've been reading up a lot on the subject but I cant find anything on OBD2 to 1 conversion and tuning associated with it. I want to buy an OBD2 cable and some software to get a better look at my car.
Anyone recommend any good software at low of free cost? My cars having issues with a surging from open to closed loop and I think this could save some money.
At the same time I wanna be able to hook up my p28 chipped ecu and get some readings from my cars performance once this problem is fixed.
Can I use an OBD1 diagnosis program on my computer with an OBD2 cable hooked up since my car doesn't have an OBD1 port for the p28?
Also, anyone have a 97 Accord F22B1 bin file? I can only find 95 and older. I wanna see in crome what it looks like stock and then some recommendations for what I should have it tuned to with the bolt on mods I have.
Thanks
Old Aug 23, 2012 | 10:33 PM
g22cd5's Avatar
Supper Moderator
you will need to get a obd2 to obd1 conversion harness. Then you will need to get your p28 chipped with a tuning softer ware like crome. A 94-97 accord ecus are the same since the engines are the same as well. The only difference is 94 is obd1 and 95-97 ecus are obd2.
Tuning your car is not easy and take a lot of time to learn. Also very easy to mess up your base map and cause damage to your engine (exp.- running to lean and frying your piston rings and or blowing your engine)
RobinsonRicer
Jan 29, 2013 10:44 PM
RobinsonRicer
Aug 9, 2012 08:42 PM
supercd5accord
Mar 19, 2012 01:53 PM
spool666
Feb 2, 2008 08:30 AM
Blacklisthunter
Nov 14, 2005 05:57 PM
