G23 info
Old Dec 4, 2007 | 01:38 PM
falkore24's Avatar
Default RE: G23 info
It depends on the amount of boost that you want to push ..... I posted on another thread what compression ratio results from both heads ..... are you trying to have the turbo and VTEC or do you plan to eliminate the VTEC ..... one has it and the other doesn't .... too lazy to look up the Wiki right now.
Before you do anything though, I'd try to find actual dyno maps to compare so that you can predict the actual benefit.
Old Dec 4, 2007 | 01:40 PM
00AccordLX5spd's Avatar
Registered User
Of course the results will vary. This is a "frankenstein" motor. there's no telling what kind of gains any particular build will get you cause I nothing can be exactly the same when your swapping around parts from used engines.
Old Dec 4, 2007 | 01:46 PM
KevinAccord's Avatar
yeah i guess... i'll make sure i have enough info before i get into something serious... thanx guys... and Jon, thanx... didn't knew the exact #'s, i thought hey were talking to the crank as well...
Slowone11
May 2, 2013 09:17 PM
medinabeast
Aug 28, 2012 09:38 PM
sanchdaniel
Feb 27, 2012 06:37 PM
OahuGrown96744
May 1, 2011 10:06 AM
Arlon
Apr 19, 2009 08:24 AM
