Is it possible?
Old Dec 5, 2007 | 09:10 PM
mmazb3's Avatar
Default Is it possible?
Hi, I am very bad in car mechanics and probably for most of you my question will seem stupid but is it possible to put 2001 Civic HX's engine into 1996 Accord? I just have my wrecked Civic in front of my house and it's engine was beautiful compared to Accord's. I know they are different and Civic's engine is almost half a liter smaller and Accord much bigger. I am just curious. Thank you.
Old Dec 5, 2007 | 11:10 PM
nafango2's Avatar
Default RE: Is it possible?
dont quote me on it, but it would spin backwards, so it would require serious modification, but anything is possible if you have a plasma cutter and a welder!
Old Dec 5, 2007 | 11:16 PM
There should be plenty of room in the Accord's engine bay for the smaller engine.
The Accord is much heavier. The Civic engine would be overwhelmed & overworked.
The structure around the front, and the engine mounts are probably in all the wrong places. So it would be really expensive to have someone fabricate a structure to hold the Civic engine.
The engine/transmission assembly participates in the structure during a crash. Installing an engine that's that much different might be a problem if you were in a serious collision.
Other than that...
Old Dec 5, 2007 | 11:20 PM
ORIGINAL: nafango2
Civic's D-series engine & Accord's F-series spin the same way as each other. Opposite from most of the rest of the world, but the same as each other.
Old Dec 6, 2007 | 10:12 AM
00AccordLX5spd's Avatar
Registered User
I agree with the above. The Accord is way too heavy for that little civic engine. It would likely be trashed after 50k or so.
Buy a cheap Civic with no engine or a blown engine in it and swap the engine in there!
Old Dec 6, 2007 | 10:17 AM
falkore24's Avatar
x2 .... you could do it, but an accord is too heavy for a civic engine
Old Dec 6, 2007 | 10:25 AM
Good Information there Jim..thanks for posting that..
[IMG]local://upfiles/22/D822E182CE024C8FA26CBE6141B0D0CE.gif[/IMG]
Old Dec 6, 2007 | 05:47 PM
mmazb3's Avatar
Thank you everybody. Maybe I should try to follow 00AccordLX5spd's advice.
abhijitgp
Aug 26, 2006 02:13 PM
dj.fli4rt
May 30, 2006 01:37 PM
GOTTI
May 15, 2006 11:09 PM
WifeysBrokenJetta
Mar 28, 2006 07:04 PM
MartaH
Jan 23, 2006 09:23 PM
