Guaranteed horsepower for $2000 on V6?
Old Sep 14, 2014 | 07:47 PM
shipo's Avatar
Originally Posted by Hot Brass
How about a pair of RV6 HFPC High flow pre-cat headers for 26WHP,RV6 J-pipe for 10 WHP,that's extra horepower supposedly for a bone stock V6? HB
I've heard all manner of such claims, and yet rarely, if ever, have I seen such claims been proven.
My standard statement in such situations, if you want a faster car, sell your car and buy a car designed to be faster by its manufacturer. Not only will this methodology cost you less, but the car will most likely be much more reliable and hold its resale value longer/better.
Old Sep 19, 2014 | 08:52 PM
Scottwax's Avatar
J-pipe definitely makes power and if your state doesn't do a visual you should pass assuming the 9th gen 3rd cat isn't monitored like the 7th and 8th gens. Precat deletes are good too but you may get a CEL and it won't pass a tailpipe test or a visual inspection. Plus you'll have to add a resonator to the exhaust to cut down on the rasp and drone.
Personally, if it was my car, I'd just do the j-pipe and spend the rest on larger anti-roll bars, upgraded struts and a mild drop.
Old Sep 19, 2014 | 08:55 PM
Scottwax's Avatar
I've seen dyno results of the XLR8 v2 J-pipe, 19 hp and 30 lb ft on a TL type S that was stock except for a K&N intake and a test on a 7th gen Accord where the v2 gained 10 hp and 9 lb-ft over the v1 j-pipe and an RV6 test pipe.
Old Sep 19, 2014 | 10:03 PM
shipo's Avatar
And did you retest a few weeks later after the computer had a chance to catch up with the changes? Chances are the net result was two maybe three horsepower at the most on the TL, and even then, only at high RPM at WOT.
Old Sep 20, 2014 | 09:02 AM
Scottwax's Avatar
Anyone who has an XLR8 j-pipe will tell you the improvements are noticeable and permanent. There are guys on v6performance putting down 250 to 270 hp at the wheels with j-pipe, pre-cat deletes, J35/37 intakes, port and polish lower runners and TBs, 4" cold air intakes, etc and running well into the 13s. And that's on the stock cams. Those using TL-S heads/cams are making even more. Honda J series engines have a lot more potential than people realize. And if your mods exceed the ECU's ability to handle, there are aftermarket solutions like Hondata.
Do you really think going from the stock j-pipe on the left to the XLR8 v2 pipe on the right is really only going to be worth 2-3 hp?
By moving the merge back, its basically the same effect as lengthening the collector on a set of headers. Big gains in torque, which is what Honda engines really need.
Attached Thumbnails Guaranteed horsepower for 00 on V6?-20131213_124051_zps3d29b22f.jpg
Old Sep 20, 2014 | 07:10 PM
woody31's Avatar
Almost A Senior Member
nice description and picture, i bet it would be a vast improvment.
Old Sep 21, 2014 | 06:39 AM
  #17
Hot Brass's Avatar
Yeah....I am waiting on the J-pipe for the 9th Gen V6....supposed to be available around X-mas. HB
Old Sep 21, 2014 | 06:58 AM
  #18
shipo's Avatar
While there is no doubt that Accord V6 engines with TL head and/or cams produce considerably more power than a stock engine, unmodified engines with just the addition of a new J pipe will produce a only a marginal bump in power while at the same time will produce a measureable bump in pollution. Not a good trade off if you ask my lungs.
Old Sep 21, 2014 | 08:47 AM
  #19
Scottwax's Avatar
Considering the precats are still there, any increase in pollution is going to be negligible, otherwise the federal government would have made Honda monitor the 3rd cat. I had a '77 Cutlass with a 455 swap a long time ago and with no cats at all, it was .12 in CO2 away from passing the standards for a 1977 car with catalytic converters the first time through. Simply adjusting the idle mixture was enough to bring it into compliance. Modern cars using computer controls and using unleaded gas already burn a lot cleaner than cars from the 60s and 70s. That's not to say we should remove all pollution controls and everyone run catless, but removing one of three (and believe me, the 3rd cat is minimally restrictive anyway) isn't going to turn a modern car into a mid-60s big block running rich and loading up at idle.
And removing the precats and replacing them with precat deletes, you're on your own with that...even if you don't get a CEL (there are O2 extenders already welded in), you won't pass a visual and would have a tough time with a tail pipe test because unlike older cars, you simply can't lean a newer car out at idle by turning a couple screws.
In the end, someone with a 7th or 8th gen Accord, the only exhaust mods that make any real power are the precat deletes and the j-pipe and since the j-pipe is the one that will keep the vast majority of us able to pass annual inspections, its the best choice.
1bdvet
Jul 11, 2012 03:00 AM
bullet099
Nov 27, 2005 03:52 AM
zelseman
Nov 17, 2005 07:29 PM
89LXi
May 23, 2005 05:59 PM
Shocker
Apr 21, 2005 09:48 PM
