Head removal?
Old Jun 25, 2014 | 12:12 PM
mancar72's Avatar
Default Head removal?
Need some advice. I have a 2006 accord with a 4 cyl. Head Gasket is leaking I have head lose but the timimg chain guide is keeping it from coming out. Do I have to take timing cover off or what.
Old Jun 25, 2014 | 12:35 PM
shipo's Avatar
Originally Posted by mancar72
Need some advice. I have a 2006 accord with a 4 cyl. Gasket is leaking I have head lose but the timimg chain guide is keeping it from coming out. Do I have to take timing cover off or what.
Which gasket is leaking, the head gasket or the cam cover gasket?
Old Jun 25, 2014 | 01:05 PM
mancar72's Avatar
Head gasket
Old Jun 25, 2014 | 01:30 PM
Timing chain must be removed from camshaft sprocket. This requires removal of crankshaft pulley, timing covers, etc to access the chain.
I don't know of a short-cut, but I have seen folks suspending the chain and pulling head over chain (in other models, not Accords!). Sprocket/s w/ chain would need to be removed to enable this feat. No easy matter there either. You might check youtube for this option.
You need a shop manual before doing anything. Suggest checking w/ automanualsource.com for a download manual, $22 a bargain.
Old Jun 25, 2014 | 01:51 PM
mancar72's Avatar
I got the cam sprocket bolt off and sprocket is hanging out of way, but the chain guide is attached to head and I figured it whould slide up with the head and its not, cant find much on u tube. Might get that manual. Thanks
JasonSater
Oct 25, 2012 11:59 AM
rtmobile96
Sep 27, 2007 03:30 AM
dcsmith
Jun 3, 2007 02:45 PM
dodins
Mar 18, 2007 08:10 PM
commodore
May 19, 2005 11:11 AM
