head shave-compression increase
Old Sep 18, 2008 | 08:08 AM
jcocker03's Avatar
Default head shave-compression increase
ive heard you can shave your head as an easy way to increase your compression. ex.-ive got a friend who shaved the head on hisstock neon down .030, and he's got a very noticeable increase in power; neons are slow, but with the shaved head and a 5spd that neon runs even with my 91 accord 5spd. most embarrasing.
Any opinions on doing this to the head on a f22a1? im a machinist so it would be very easy for me to do myself.
Old Sep 18, 2008 | 08:57 AM
08coupex's Avatar
Default RE: head shave-compression increase
In theory it sounds right but you risk the chance of blowing out you head gasket. If your going to deck the head or heads you might as well port and polish them the maximize hp or just get a better head.
Old Sep 18, 2008 | 09:57 AM
falkore24's Avatar
Not to mention that these are interference engines and if you shave too much, you are going to ram a piston into the valves. A non-interference engine .... it's a good idea. Honda engines ..... I wouldn't.
Old Sep 18, 2008 | 11:43 AM
jcocker03's Avatar
Could'ntI over tourqe the head a little to avoid blowing gaskets?
I planned on porting the head.
Old Sep 18, 2008 | 12:05 PM
08coupex's Avatar
No the torque spec is there for a reason. You would risk blowing out the head gasket even more if you over tighten the head bolts.
Old Sep 18, 2008 | 12:34 PM
falkore24's Avatar
If you deck the head so it is level and use a Cometic gasket AND torque to specs in the proper order, I don't think you will have a head gasket issue. I'd be more concerned about killing the entire engine by crushing the valves with the pistons.
SVTMike
May 13, 2014 01:46 AM
AyashiFX55
Jun 7, 2009 10:51 AM
mech_e
Nov 25, 2007 12:53 PM
WhiteWolf
Oct 8, 2007 11:27 AM
thunder_x
Sep 1, 2007 11:05 PM
