Help please
Old Apr 10, 2011 | 10:40 AM
vedockv's Avatar
Default Help please
My speedometer has been working intermittently and my cruise control has been going on and off also. I was told by several mechanics that i needed to change the VSS its an LX w/o abs so there is only one-the main shaft speed sensor on the transmission? So i tried replacing that and that didn't fix the problem. Next i was told that it was a wiring problem. So i checked the continuity of the vss wires and i have no power going there or back. but if there was no power then why would the speedometer work intermittently? that wouldn't make sense if there is no power. I also noticed a clicking noise, my mechanic next door said it a was a relay (i trust his opinion as he was a mechanic for 35+ years) the only problem is I can't for the life of me find where the clicking sound is coming from and neither could he. The speedometer fluctuates in rhythm to the clicking. Every time it clicks the speedometer jumps-varying from 0 to 120 to 80 to 140 (THIS IS WHEN I'M NOT EVEN MOVING! ) It sounds like it was to the right of the oil filter and in/on the transmission box. If anyone can help me Please Do. I'm wondering what could be causing all of these problems and where the vss relay is or if there is even a relay? And if there is not a relay what could be causing the clicking noise sounding like its around the transmission?
Old Apr 10, 2011 | 01:16 PM
Is this on the 97?....and nice to see someone else from NC.
Do you have pic's of the part that was replaced? Main shaft sensor and VSS are not the same (IMO)..
Old Apr 10, 2011 | 01:40 PM
engtaz's Avatar
Almost A Senior Member
Welcome, sounds like a speedo cable issue but I'm not familiar with your model.
Old Apr 10, 2011 | 02:02 PM
Not sure how these pic's will come out....Can you tell which was replaced.
Attached Thumbnails Help please-97-shaft-sensor.jpg   Help please-97-speed-sensor.jpg
Old Apr 11, 2011 | 01:58 PM
vedockv's Avatar
Its the long cylndrical one. My lx is a japanese model (Vin # starts with a J) and doesn't have abs. I have not been able to find that other speed sensor on the right* anywhere on my car?
Old Apr 17, 2011 | 12:17 PM
Sorry, don't get in this part too much. I think it is behind a small cover at the "end" of the trans. Is this a 4 or 6 cyl model.
Hope you didn't get any damage in the storms yesterday....I spent most of the afternoon cleaning up trees and limbs, nothing landed on the house but a mess for sure.
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
mamtsberg
Mar 17, 2010 09:15 PM
BIGWILBO
Apr 5, 2008 07:57 PM
ryan ortego
May 19, 2005 06:06 PM
