How much hp?
Old Jul 23, 2008 | 06:42 PM
lowandslow's Avatar
Default How much hp?
Ive been thinbkin bout just keeping my stock motor and boostin it.with the turbo and cam,pullies,everything how much u think i can pull?
Old Jul 23, 2008 | 06:59 PM
clutch811's Avatar
Default RE: How much hp?
whats your car/year/motor? that would help in getting you an answer.
Old Jul 23, 2008 | 09:01 PM
lowandslow's Avatar
91 lx...i thinks its a F22?
Old Jul 24, 2008 | 11:54 AM
clutch811's Avatar
personally im not a boost expert but i do know you're pushing as honda claims 125HP stock. boost hp comes down to how good the engine is and how much boost you add. from as low as 5 psi to 25 psi. i have an f22b2(130hp) and as long as its solid enough i can boost with stock internals at around 6 or 8 psi and get around 200 to 220 hp. i could say if you can with stock internals maybe 200 hp at the same psi or if you build it you get even more at a higher psi.
whats your mileage, whats been kept up on and such with the car?
Old Jul 24, 2008 | 01:19 PM
falkore24's Avatar
Provide more info. The same setup can produce 180HP or 250HP depending on the tuning.
Old Jul 24, 2008 | 01:41 PM
KevinAccord's Avatar
I don't think you'll reach 200hp at the wheels @ 6psi... maybe, just maybe @ the crank
Old Jul 24, 2008 | 01:54 PM
falkore24's Avatar
^^^ depends on the setup. A GT35 turbo could put that much power through a 4 cylinder on low boost. All depends on the matching and the tune. A 16G snail wouldn't put out as much power with 50% more pressure.
Old Jul 24, 2008 | 02:01 PM
yeah, but his car is 125hp stock @ crank... @ the wheels is more like 105hp if not less... you really think you can reach 200hp @ the wheels @ 6 psi?
Old Jul 24, 2008 | 02:09 PM
falkore24's Avatar
not likely, but possible.
Old Jul 28, 2008 | 06:41 AM
oh well... i still think that 100% increase on 6 psi is far less likely than a 25-50% but who knows... maybe w/ other mods it can get close...
RobinsonRicer
Dec 22, 2013 08:42 AM
Sadus
Sep 6, 2011 11:29 PM
NICK63
Nov 2, 2009 11:57 AM
kartracer72
May 15, 2005 07:02 PM
