J30A4 head and cam upgrade
Old Nov 6, 2018 | 10:44 AM
Siraxious's Avatar
Default J30A4 head and cam upgrade
Hey everyone, im reaching out to the community to see if i can find some sources on performance heads and somewhere around stage two or semi type racing cams for my 03 EX accord. Right now its a stock J30A4 V6 but im looking to do a major overhaul of the engine and throw a new transmission in it. Not a hundred percent sure on the model of the transmission but it is the 5 speed auto. Also has anyone had experience with the HTSpec J37 Magnesium intake manifold? In any case any sources or info on where to look or recommended parts to match up that's proven to be a nice upgrade for this model engine with be very helpful.
Old Nov 6, 2018 | 11:54 AM
shipo's Avatar
I'm thinking it would be better/faster/cheaper to simply buy a 2004-2006 J32A3 (Acura TL), or a 2005-2010 J35A6 (Honda Odyssey LX and EX). As for the transmission, look for a BAYA unit from a 2006-2007 V6 Accord.
Old Nov 6, 2018 | 12:07 PM
Siraxious's Avatar
speaking of acura what would your option on the 2015 TLX SH-AWD? it has the 3.5 v6 with a 9 speed auto/Shifter paddles. I figured if i was to pull a swap from the acura line as far as engine and a trans on the newer model accord that i would do a upgrade as far as a newer style acura.
Old Nov 6, 2018 | 01:32 PM
shipo's Avatar
If you have enough money, like 5-figures, anything is possible. The two engines I listed above are more or less, straight bolt-ins for your car.
Old Jun 22, 2023 | 06:01 PM
HondaChACE's Avatar
out of curiosity which bolt off / ons work from the tlx and oddessey?
I too am looking to further build my j30a4 6 speed accord when i overhaul it. Im not looking for rediclous power but closer to 400 would be nice an fun yet still daily drivable if i wanted to use it often.
Old Jun 22, 2023 | 09:08 PM
shipo's Avatar
Ummm, 400HP? Probably not going to happen without a fair amount of money; how much do you want to spend on the project?
Regarding which engines; tell me the year and model of your car and which engine is currently in it.
Bw0nz1ca
May 1, 2012 04:50 PM
Sethgreen
Aug 4, 2011 01:58 PM
hondata03
48
Jul 5, 2008 09:14 PM
bssmagik83
Aug 9, 2007 03:08 PM
bssmagik83
Apr 10, 2007 07:56 PM
