Location of the fuse/relay of the fuel pump??
Old Nov 15, 2015 | 02:43 PM
Argie's Avatar
Default Location of the fuse/relay of the fuel pump??
Hello everyone. I think i might need a hand.
My Accord isnt starting, and it appearts that the fuel pump is not working.
So i guess the problem could be the fuse or relay for the fuel pump. But i dont have the electric scheme, so im not sure where they are.
Also... if the relay/fuse (im not even sure what does it have) is broken. Which other Honda uses the same relay?
Because finding spare parts for this model here in my country is a real nightmare. Local Honda dealers cant even find this model in their catalogs (lol, yes, believe it or not).
The Accord is a 1989 with a a20a4 engine and fuel injection, made in Japan.
Thanks
Old Nov 26, 2015 | 10:56 AM
On the 3rd gen FI engines the main relay for the fuel pump is up high to the left of the steering wheel. If you remove the coin holder/fuse cover and look a little up and the the left you should see the relay.
Old Dec 21, 2015 | 07:06 PM
Argie's Avatar
Thanks! I found it, and yep. There it was, the mitsuba rz0088, and it was the problem. A solder inside was broken. I had to repair it, because unfortunately no way i could find a new one.
Hidden lights
Mar 3, 2015 06:39 PM
Fubz
Dec 27, 2012 10:26 AM
greg05
Aug 31, 2009 05:32 PM
kissbally78
Jan 18, 2009 07:14 PM
grimace007
Jun 18, 2007 09:22 PM
