main relay smoking.
Old Mar 4, 2012 | 03:33 AM
Jap.Doe's Avatar
Default main relay smoking.
so after starting my car and driving it my main relay under the dash heated up, then started to smoke. what could cause this?
also theres a major oil leak from the head, i just replaced the gasket so whats the possiblility with that as well. thanks in advance.
Old Mar 4, 2012 | 07:11 AM
crispin's Avatar
for the Main Relay
I would say that it is either a failing relay (IIRC you just replaced the Relay recently) so I would go to replacing the ground wire for the relay.
I have already had to replace a few grounds on my Honda that failed. So pull up the wiring diagram, find out which wire is ground, and add another ground wire to it.
I do not like to cut out the old ground, I normally leave it and just add another wire to it going to a good ground as most times multiple circuits share the same ground wire.
I just had a recent problem where the wiper came on whenever the DS blinker was turned on (yes odd wasn't it) Ended up being a bad ground wire at the front DS bumper blinker bulb.
Old Mar 4, 2012 | 10:45 AM
The reason they fail so frequently is they get very hot. I measured about 110F on case w/ IR temp scanner on bench testing an MFR. Any oil or material left might begin to smolder.
skareb
Aug 26, 2010 06:41 AM
greg05
Aug 31, 2009 05:32 PM
jrcastro
Jun 26, 2006 09:20 PM
deserthonda
May 12, 2006 03:44 AM
Cleric
Dec 26, 2005 09:09 PM
