No heat on passenger side - 2007 V6 EXL w Nav
Old Jan 10, 2024 | 02:28 PM
osurh18's Avatar
Default No heat on passenger side - 2007 V6 EXL w Nav
I have a 2007 Honda accord v6 EXL. I no longer get heat on the passenger side. Also the air coming out of the center two vents above the nav is cool as well.
It sounds like it might be a blend door actuator… But I wanted to ask this group to see what they thought. Next to the cabin filter in the glove box is the actuator that I have been told could be the problem. When I turned the heat all the way up and then the temperature all the way down I don’t see the two white arms on the actuator move. Please let me know what your thoughts are.
I also see an actuator to the left of that that looks like it mounts to the center consul and I’m not sure if that is the actual one that could be causing the problem. Thank you in advance
DFRITTS
Jun 6, 2021 08:18 PM
dnp
Oct 22, 2020 05:30 PM
rick_esco
Oct 26, 2014 06:28 PM
penleydr
Aug 17, 2009 11:19 AM
jdgret
Sep 13, 2007 03:38 PM
