O2 Sensor - Front / 2005 Accord 4 cyl
Old May 1, 2011 | 08:18 AM
frankrentef's Avatar
Default O2 Sensor - Front / 2005 Accord 4 cyl
Thanks for the help in advance. I'm looking for a "how to" on changing the front O2 sensor on a 2005 Accord LX 4 cyl. I can find dozens and dozens of "how-to's" on the back / rear O2 sensor, but not one of any detail on the front O2 sensor.
Frank
Old May 1, 2011 | 08:57 AM
The primary sensor is a Air-Fuel Sensor (more expensive) and is located just below exhaust manifold. Access will require elevating the vehicle on jack stands. An open-end wrench or O2-sensor socket is necessary to remove the sensor. It may be tight.
Check youtube for videos for "honda accord sensor" for a little help.
Check O2 sensor replacement videos. It's same procedure.
Old May 1, 2011 | 11:05 AM
Default Accord 2005 4 cyl O2 Sensor (Front)
Thanks for the tip on the U-Tube...after looking at about 80 from the search results....strike out. Amazing how a search for an Accord returns Chevy Suburban (O2 Sensor). Probably is one in there somewhere....
Thanks
pondrun
Nov 8, 2021 09:40 AM
njny2003
May 25, 2015 09:05 AM
tony_toca
Feb 5, 2011 09:56 AM
mrmatrix
Aug 12, 2006 05:39 PM
MI_CM_ACCORD
Sep 27, 2005 04:42 PM
