Oil changing and factory warranty
I do my own oil changes; that way I know the right stuff is in the engine. As for the changing of the crush washer on the drain plug, I avoid that situation by using an oil extractor which pulls the oil out via the dipstick; haven't pulled a drain plug since 1999.
If it comes to pass I'm unable to perform my own oil changes, I will use a small independent local shop to do the actual work (I will still buy the oil and filter).
By using the pump method, isn't there the possibility of a sludge build-up in the bottom of the oil pan?
That said, who cares about sludge/sediment in the bottom of the pan? I ask because sediment in the bottom of the pan is pretty much inert; it'll stay there until you junk the car (or roll it into a ditch, which ever comes first).
Quite the contrary; the first time I used it on one of our cars which had, to that point, had conventional oil changes via the drain plug, I could not believe how much sediment was sucked out from the bottom of the pan.
If my dealer had its way, I'd have to breath Honda air, drink Honda water, and eat Honda food, otherwise the warranty would be voided
If there is a dispute as whether the warranty should be honored, the burden of proof is on the manufacturer that the owner neglected to reasonably maintain the car. There is nothing saying that the car has to be serviced at a dealer.
For the last 35 years, I maintain my own cars, never had any problem with warranty.
OP they cannot force you to have service done at dealer, research local shops and ask around.
You just can't get good service anymore is the general undertone I am hearing. I can do, and I have done my own oil changes, I just find disposing such a hassle and a serious potential mess!
Thanks for the thoughts!
Our town has a bin for recycling automotive fluids. That and most of the shops I buy my oil from take used oil for recycling.
