oil leak...
Old Jan 31, 2008 | 11:46 AM
ohiostatepimp22's Avatar
Default oil leak...
I have an oil leak around my oil filter i have a 94 accord and i was just wondering if anyone has had the same problem. I got the engine dye to see exactly where. But i believe its what the oil filter screws on i believe i torqued it too tight resulting in maybe a crack in it. Does anyone know the name of this part??
Old Jan 31, 2008 | 11:55 AM
nafango2's Avatar
Default RE: oil leak...
how did you tighten the oil filter too tight? i cant really see that happening unless you used a wrench to tighten it.
make sure that the old gasket from the old filter isnt stuck to the block anywhere.
Old Jan 31, 2008 | 11:56 AM
yea i did its clean as can be..i talked to a buddy of mine and he said that maybe i could have over tightened it which it was really tight
Old Feb 1, 2008 | 12:24 AM
Nova's Avatar
Did you replace it with the right filter?? You may have gotten a filter which is too big, but will still screw on.
Old Feb 1, 2008 | 09:53 AM
i looked in the book and matched it up in the book at autozone. So i have no clue what is wrong
Old Feb 1, 2008 | 10:35 AM
sir_nasty's Avatar
since we're talking about a relativly inexpensive part here I'd just take the old one off and replace it with a honda filter. make sure the block is clean from all old debrie and oil, tighten down the honda filter as tight as you can get it with one hand, then use an oil wrench and go 1/4-1/2 turn more and try that.
Old Feb 3, 2008 | 08:07 AM
norm1971
I have a 2007 Accord wich is loosing about 3/4 of a quart of oil every 3500miles. My concern is will this gets worse as the car gets older.
Plannig to call Honda a document this just incase I needa new engine at 100k.
Anyone else see this in their accords?
Old Feb 3, 2008 | 11:25 AM
BlkCurrantKord's Avatar
Geez..my 10yr old F23 doesn't lose any oil or if it does its hardly noticeable.
Old Feb 3, 2008 | 11:43 PM
19Accord97
Fram 3593a
Thats their oil filter part. Did you put clean oil on the rubber gasket of the new oil filter before screwing it on? Also, after you remvoed your old filter did you wipe away all the grime and oil so the new gasket/filter has a clean surface?
Oil filters are a lot thinner these days then they used to be. I never tighten mine on with a wrench. Instead I tighten them until the gasket makes contact, put a mark on the filter and crank it almost a full turn/where it is really tight!
But yes, overtightening could have easily caused a small pinsized hole. Have had it happen before.
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
mamtsberg
May 30, 2010 07:04 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
