Please Help! 97 Accord
Old Sep 2, 2015 | 11:45 AM
Davidf8322's Avatar
Default Please Help! 97 Accord
I have a 1997 accord se 2 door 4 cylinder with 170,000 miles and I have oil in my spark plug tubes... Again...
This is the 6th time this has happened in the past 3 years. The first couple of times I did the upper O rings and seals myself and that fixed the problem each time for about 6 months each, then ln took it to a shop after it had leaked again and again for them to replace both upper and lower rings and seals, but same thing. About every 6 moths it seems to fill the spark plug tubes back up. Anyone have any ideas on another possible problem/ solution?
Old Sep 3, 2015 | 05:13 PM
Hard to call but something doesn't seem right.
Is it possible the upper seals are going on upsidedown? Not sure if the aftermarket has just the upper seals bit I lnow the dealer will have them. You can pull the cover them inspect the upper seals then replace them with new ones - be sure which side goes where - and see what you have from there.
LONO100
Aug 11, 2012 06:21 PM
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
mamtsberg
Mar 17, 2010 09:15 PM
BIGWILBO
Apr 5, 2008 07:57 PM
