Pulley?
Old May 1, 2008 | 06:52 PM
BuntinBoy9's Avatar
Default Pulley?
Is this a good set up for the price????
http://cgi.ebay.com/ebaymotors/OBX-P...QQcmdZViewItem
Old May 1, 2008 | 09:32 PM
HORSEPOWERJUNKIE2007's Avatar
Default RE: Pulley?
i've heard those give you no type of gain in HP or Torque what so ever so i really don't know what to tell you.if you looking to sup your engine,resleeve and boost.
Old May 2, 2008 | 01:10 PM
falkore24's Avatar
Default RE: Pulley?
The accessory pullies don't get much of a gain. The crank pulley is where the gain is. I had the full 3 pulley set from UR. If you are on a tight budget and want a pulley, go with the crank pulley from UR. If you want the full setup, still go with UR.
HPJ: Pullies, like a lightened flywheel have no potential to make horsepower or torque. They reduce the parasitic inertia caused by the rotational mass. A lightened pulley or flywheel allows the engine to rev up and down faster allowing faster acceleration, but peak #'s don't change. The area under the curve does grow and that's what matters.
Old May 3, 2008 | 02:49 PM
BuntinBoy9's Avatar
Default RE: Pulley?
ok yeah i knew i wasnt aimen for numbers but i mean im not going to be running at those higher numbers anyways but the faster acceleration i could use and thats what i thought a pulley set would do ... thanks for backin my thinkin up... also thanks i will definently look in to the UR crank pulley i appreciate it.
Old May 3, 2008 | 06:23 PM
finch13's Avatar
Default RE: Pulley?
They sure do look purty though!
Old May 3, 2008 | 10:09 PM
BuntinBoy9's Avatar
Default RE: Pulley?
yeah but i would rather them be butt @$$ ugly and do their job than be all nice lookin and do squat... as of right now i dont need to show off my engine bay lol
Old May 3, 2008 | 11:48 PM
Default RE: Pulley?
so pulley's help...wow i learned something because i was told by a person on this forum that they are worthless but of course that person will not be mentioned[&:]
Old May 5, 2008 | 10:14 AM
falkore24's Avatar
Default RE: Pulley?
I think they help a bit .... only in acceleration though, a dyno won't show it.
Old May 5, 2008 | 01:53 PM
KevinAccord's Avatar
Default RE: Pulley?
as falkore mentioned light weight pulley will help u rev faster allowing for faster response... no extra anything what so ever.... but taking 300lb of your car doesn't add HP but does make the car faster...(get my point?)
Edit: forgot the question mark...ooooppppppsssss!
accordfan222
Oct 14, 2007 07:19 AM
moto310
Apr 30, 2006 03:16 PM
01hondaccordlx
Mar 7, 2006 05:05 PM
redlines
Oct 10, 2005 06:13 AM
igotjshoe
Jun 6, 2005 10:50 PM
