Pulsating idle
I swap my 99 accord, the engine fires right up after but it has a pulsating annoying idle....it goes 1000k to 1500k RPM bouncing like crazy. I saw a lot of thread about this problem of honda civic and accord...so far check all my hoses, they are right on to were they suppose to be....Any suggestion I would take in consideratin..
How did you check all the hoses? They may be in the right place, but might have a leak. Get some carb cleaner and spray all the vacuum hoses and the gasket areas for the intake. That's usually when you find the problem. If that's not it, try checking your FITV (if your car has one) and your IAC valve. Cleaning the throttle body probably wouldn't hurt either
have you tried searching this site for an answer yet?
it has been covered like 1 billion times already
how to fix an erratic idle <<<<<<<<<<<<click this to search for your answer.
90pioneer
Apr 9, 2012 09:06 PM
fperezal
Jun 14, 2006 05:03 AM
