quick question
Old May 31, 2006 | 10:45 PM
rrive1
Default quick question
I HAVE A 2000 ACCORD SE 4DR ULEV VTEC AUTOMATIC TRANY I WANNA KNOW WHAT SWAPS ARE RECOMMENDED H23A OR STOCK F23A AND SWAP TO A MANUAL TRANY AND GO TURBO
Old Jun 8, 2006 | 08:05 PM
sir_nasty's Avatar
Default RE: quick question
if you want to go turbo I'd go with a SOHC engine... DOHC engines work best for naturally aspirated SOHC are great for turbo's...
Old Jun 8, 2006 | 11:11 PM
YeuEmMaiMai's Avatar
turbo your current motor
Old Jun 9, 2006 | 12:21 AM
poff1986's Avatar
Id get a non-vtec engine DOHC so that you can just swap it in, and throw a turbo on it and run low boost like 6-9 PSI.
Old Jun 9, 2006 | 03:33 AM
marbro's Avatar
sir nasty, the fact that its a dohc has nothing to do with it being a good turbo setup or not, its just most of the dohc engines honda has dont have cast iron in the cylinders/cast iron sleeves, and on top of that they are a shorter stoke then most of the sohc versions
shorter stroke = less torque
Stopormymomwillshoot
Aug 29, 2010 06:18 PM
get'er go'in
May 4, 2010 12:33 PM
emaxxman
Mar 1, 2006 01:32 AM
thunder_x
Oct 3, 2005 12:56 PM
thunder_x
Oct 3, 2005 12:35 PM
