really loud and sweaky belt
Old Jan 6, 2009 | 01:18 PM
Roadrash98vtec's Avatar
Default really loud and sweaky belt
My belt is extremely loud and sweaky any way to tighten or fix it? is it a pully?
Old Jan 6, 2009 | 02:11 PM
finch13's Avatar
Default RE: really loud and sweaky belt
There are tensioners for each of the accessory belts. One on the power steering pump and one on the alternator. Kind of hard to explain but easy to do... just loosen up the bolts so the alt/pump can swing and then use the adjuster bolt to adjust tension on the belt. Its something like 1/4" deflection in a 7" span of belt or 1/2" deflection in a 13" span of belt. A Haynes manual will do you good.
Old Jan 6, 2009 | 02:46 PM
The belts will get hard & slippery with age; then they squeak more. Its tempting to over-tighten the belts, but then youll be asking about how to replace alternator bearings...
Squirt water on the belt while its squeaking. If the squeaking does NOT stop, then maybe the noiseIS bearings instead of the belt.
Old Jan 6, 2009 | 02:58 PM
MrGmo's Avatar
they sell belt spray at autozone... mine would sweak when i started it up... i sprayed it and went away for about three days... it still doing it when cold... im thinking of just replacing the belt! lol
Old Jan 6, 2009 | 03:27 PM
finch13's Avatar
Just replace the belt, the spray is a gimmick. If you want to save some money on a belt... just take the A/C and P/S out and use the DX belt... thats what I did! lol
Old Jan 6, 2009 | 06:59 PM
thanks guys
sanchdaniel
Oct 7, 2010 12:38 PM
jenny
Oct 9, 2008 09:27 AM
sbutler
Apr 23, 2008 11:46 AM
rtmobile96
Apr 10, 2008 12:43 PM
thunder_x
Jul 29, 2006 09:11 PM
