WHICH SHOULD I INCREASE FOR MY LX?
Old Dec 1, 2008 | 09:39 PM
falkore24's Avatar
Default RE: WHICH SHOULD I INCREASE FOR MY LX?
ORIGINAL: noehjuan01
get a cam gear and advance it by 4 or 5 degrees for better take off acceleration, since you already have exhaust system your bottom end torque is shifted to a higher rpm range
mine is a '98 lx 4cyl, had air intake and exhaust, the cam gear really helps shift the torqueto low/mid rpm range
Do you have a manual or something with directions on how to set those gears properly? I've always been interested in those things, but other than dyno testing, I don't see a good method to determine how much to move it, also I'm concerned about the potential for damage especially considering that these are interference engines.
Old Dec 2, 2008 | 01:03 AM
skatingclaybird's Avatar
MAKE SURE TO TIghten them i had a friend that tHOUGHT he did and he didnt KABOOM BEND BEND BEND
Old Dec 2, 2008 | 09:44 AM
falkore24's Avatar
Seems that AEM recommends a setting in the paper that comes with the gear ...... too bad that it doesn't work with i-VTEC or VVT-i.
dallascowboysruleall
Aug 18, 2008 09:28 AM
mech_e
Nov 25, 2007 12:53 PM
petesbween
Oct 30, 2007 08:47 PM
WhiteWolf
Oct 8, 2007 11:27 AM
thunder_x
Sep 1, 2007 11:05 PM
