Temperatue Gauge/Brakes
Old Jun 23, 2007 | 05:01 PM
VIZZ1
Default Temperatue Gauge/Brakes
I have a 2002 Honda Accord 4door EX. Recently when I idle at stop or parkingthe temeprature rises very quickly. I have checked all my fuses and the cooling fans do turn on yet it still rises. There is plenty of coolant. Any suggestions? I was thinking about getting the radiator flushed.
Also, anyone have a recommendation on where to get my brakes looked at/replaced. They have been squeking a while and I believe it's time to get them replaced. I heard from so people to not go to Brake Check Plus.
Old Jun 23, 2007 | 08:02 PM
03slow's Avatar
Default RE: Temperatue Gauge/Brakes
Check your thermostat it could be bad. Same thing use to happen to me when I had an Oldsmobile Omega(heap) 2 different cars but another place to start.
Old Jun 24, 2007 | 10:42 AM
Chiovnidca's Avatar
Have you checke d the collant level? Do the fans work?
Old Jun 24, 2007 | 02:25 PM
VIZZ1
yes, coolant level is where it needs to be and the fans turn on no problem.
Old Jun 24, 2007 | 10:47 PM
KevinAccord's Avatar
are the fans spinning in the right direction? (that could be the problem if u removed it recently and installed it back.....happend to me once (very embarrasing)) good thing i found out myself...
alphaney
Feb 12, 2022 10:14 AM
pirulino23
Nov 10, 2010 06:18 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
