tranny oil change
Old Apr 18, 2007 | 01:34 AM
jbl2bgone's Avatar
Default tranny oil change
Just a quick question to people that change their own tranny fluid. I have an 01 accord EX 4cyl SULEV Auto. I tried changing the tranny fluid today by tryin to remove the drain bolt on the bottom. Can you remove that bolt by some hand tools (3/8 ratchet)or do you need to use some air tools? I had such a hard time just tryin to get it to budge, but no luck. Any help would be great? Also would i fill the tranny with new tranny fluid though the transmission dip stick? or is there a fill plug, because i cant seem to find it.
Old Apr 18, 2007 | 02:27 AM
Default RE: tranny oil change
I had to use a cheater pipe on a 3/8" breaker bar. It snapped with a loud bang when it came loose.
And YES, you fill the auto-tranny thru the dipstick hole.
Old Apr 18, 2007 | 03:24 AM
jbl2bgone's Avatar
where do you think i can get a breaker bar? any major auto parts store? You think i can just use my ratchet n use a cheater pipe?
Old Apr 18, 2007 | 06:35 AM
ckebottle's Avatar
Man, I had the same problem....this is what worked for me. I bought a longer 3/8's ratchet and let it hang perpindicular to the ground. Took a hammer and put it cross wise to the ratchet and pulled as hard as I could using both hands and it snapped. That thing was a bugger to get off! Also, not to insult you or anything (i've done it in the past) make sure you are doing left loosey.
Old Apr 18, 2007 | 10:47 AM
ORIGINAL: jbl2bgone
Most hardware & parts stores that sell sockets would alsohave breaker bars. Occasionally you'll break the ratchet mechanism if you use a pipe.
PS... Make absolutely sure the car is supported so you don't toppleit off the stands when you pull on this.
93Accord2.2
Jan 20, 2012 01:02 PM
chris h
Apr 3, 2011 10:01 AM
480Ruger
Jul 13, 2008 05:50 AM
ziwang55
Jun 6, 2008 01:25 PM
tk0329
Jun 9, 2006 08:54 PM
